[Sc...] Posted February 28, 2023 Share Posted February 28, 2023 How do I insert the program to travel to nominal position? I have round part B.C( 6x Ø .140). I want the stylus to go at X/Z location so I can rotate part to get 1st hole to align with stylus. Manual alignment on each part is time consuming. Part is on fixed vee block. The first hole Is Planar for my base alignment. ref:102820889 Link to comment Share on other sites More sharing options...
[Ju...] Posted February 28, 2023 Share Posted February 28, 2023 You could insert a CMM Position Point at the nominal location for the desired feature in that feature's measurement strategy. Link to comment Share on other sites More sharing options...
[SH...] Posted February 28, 2023 Share Posted February 28, 2023 If you want to move the probe to a particular location,at the end of the program. You can use the parking position... Link to comment Share on other sites More sharing options...
[Er...] Posted March 1, 2023 Share Posted March 1, 2023 I have used a precision square to visually line up parts before. I am a klutz, so I find ways to avoid breaking probes. 🤣 I would assume there are no other features to clock the part with a Start Alignment? "Position CMM without probing" combined with a program "stop" inside of the strategy can work. Link to comment Share on other sites More sharing options...
