[To...] Posted February 17, 2023 Share Posted February 17, 2023 I just learned something new today. This should make me the most popular guy for Friday February 17th.... If you have the latest service pack of CALYPSO 2022 (7.4.04), you can change icons back to the “classic” icons by pressing F5, then typing uoi (use original icons):uoi.jpg Link to comment Share on other sites More sharing options...
[Ke...] Posted February 17, 2023 Share Posted February 17, 2023 Please sign in to view this quote. Congratulations! I can almost guarantee that today is your day 🤣 Link to comment Share on other sites More sharing options...
[No...] Posted February 17, 2023 Share Posted February 17, 2023 I don't even have 2022 installed! 🤣 🤣 Now why would they include such a function....and hide it? 😕 Link to comment Share on other sites More sharing options...
[Je...] Posted February 17, 2023 Share Posted February 17, 2023 Please sign in to view this quote. Well that didn't take long... You must have talked to Ryan Stauffer. Link to comment Share on other sites More sharing options...
[Ow...] Posted February 17, 2023 Share Posted February 17, 2023 The new Calypso 2022 ICONS went over like a lead balloon, or maybe a white one that hung around awhile before being shot-down. 🤣 Link to comment Share on other sites More sharing options...
[Je...] Posted February 17, 2023 Share Posted February 17, 2023 One caveat to this method, it is yet unconfirmed as I haven't tested it (and the reason I hadn't posted it), you need an older version of CALYPSO installed. From what I can see, the F5 function changes the directory for the icons location to an older CALYPSO installation. So this may not be an end-all solution for everyone. If someone would be so kind as to test if they only have a single 7.4.04 install, that would be helpful. The alternate method I posted the other day (that you can access through the US Portal KB) supplies the pictures folder in the event you do not have a previous version and instructs on how to implement. Link to comment Share on other sites More sharing options...
[Ch...] Posted February 17, 2023 Share Posted February 17, 2023 Definetly a good find, and thank you Zeiss for adding this. Is this supposed to be a hidden feature ? Next question is, is there a code to revert back to new icons ? "uni" ? Great find ! Link to comment Share on other sites More sharing options...
[Ri...] Posted February 17, 2023 Share Posted February 17, 2023 Please sign in to view this quote. Congratulations, you win the internet for today. In addition, you have been banned from the Zeiss Forum. Link to comment Share on other sites More sharing options...
[Je...] Posted February 17, 2023 Share Posted February 17, 2023 . This day will be commemorated for generations. . Link to comment Share on other sites More sharing options...
[To...] Posted February 17, 2023 Author Share Posted February 17, 2023 Please sign in to view this quote. You probably aren't too far off with that one. There's couple of guys in blue lab coats coming down the hall to my office. Link to comment Share on other sites More sharing options...
[Ro...] Posted February 17, 2023 Share Posted February 17, 2023 I thought that command was Alt+F4. Do not hit Alt +F4, it just closes the current window you have open. Old mean internet trick from my days on the forums of the late 90's - early 00's. When someone would complain about something, you tell them that Alt+F4 would fix that issue, then 10 seconds later you would see their name "Has left the room". Link to comment Share on other sites More sharing options...
[SH...] Posted February 17, 2023 Share Posted February 17, 2023 Please sign in to view this quote. It is possible undo it back?? Link to comment Share on other sites More sharing options...
[Ri...] Posted February 17, 2023 Share Posted February 17, 2023 Please sign in to view this quote. It will revert after you close Calypso and reopen. I noticed that it doesn't change all of the icons. Leaves you with a 50/50 Hybrid. Link to comment Share on other sites More sharing options...
[Je...] Posted February 17, 2023 Share Posted February 17, 2023 just do the routine again F5 + uoi = swap icons. New to old. Old to new. Link to comment Share on other sites More sharing options...
[Ri...] Posted February 18, 2023 Share Posted February 18, 2023 What this really means is we can create our own Icons and use them as long as the names match? This could get interesting seeing a report with nothing but my headshot for icons. 🤣 Link to comment Share on other sites More sharing options...
[SH...] Posted February 28, 2023 Share Posted February 28, 2023 Please sign in to view this quote. It is working in our spectrum and new contura, but in our O inspect it doesn't work... Same versions .. O inspect has older version installed 2021 in addition to 2022 version.. Link to comment Share on other sites More sharing options...
[Je...] Posted February 28, 2023 Share Posted February 28, 2023 Please sign in to view this quote. Thank you for the feedback. I also had a chance to test myself. The F5+uoi function call requires the 7.4.04 Service Pack as well as a previous version of 7.2.## installed. All other versions prior to 7.2 tested (back to 6.4) had no effect. Link to comment Share on other sites More sharing options...
[Ch...] Posted February 28, 2023 Share Posted February 28, 2023 Please sign in to view this quote. Yes, in fact you should have been able to use custom icons in the past as well.. I have anyway.. provided you had amin access to C drive just copy paste edit rename, etc. I think I once trimmed all the FCF boxes .. because .. idk .. OCD ? ... 😃 Link to comment Share on other sites More sharing options...
