[Dy...] Posted February 22, 2023 Share Posted February 22, 2023 I'm trying to re-run a characteristic if the result was bad and wanted it to be rechecked again? I tried using the example from the online help but I don't want it to stop for user input or show message just re check 2 or 3 times and move on to the rest of the program without user input. Link to comment Share on other sites More sharing options...
[Ri...] Posted February 23, 2023 Share Posted February 23, 2023 Have you tried a Loop? You can set the number of iterations for the feature to run as well. Link to comment Share on other sites More sharing options...
[Dy...] Posted February 23, 2023 Author Share Posted February 23, 2023 Yes, but I didn't want to add time to the program if it checked good the first time, problem is our Eclipse with Renishaw TP20 head pops and clicks resulting in air points giving false readings, but its not consistent so when it does I want it to re-check it without having to monitor it, re-run the feature and re print the report Link to comment Share on other sites More sharing options...
[Ju...] Posted February 23, 2023 Share Posted February 23, 2023 Can loops for features have break conditions like alignment loops? Link to comment Share on other sites More sharing options...
[Dy...] Posted February 23, 2023 Author Share Posted February 23, 2023 Please sign in to view this quote. Yes, i wasn't sure how to put a range though? Link to comment Share on other sites More sharing options...
[Ju...] Posted February 23, 2023 Share Posted February 23, 2023 You can right-click on a Characteristic and then click Condition to enter the desired limits. I don't have PCM, so I am unable to guide you any further than that lol. Link to comment Share on other sites More sharing options...
[Dy...] Posted February 27, 2023 Author Share Posted February 27, 2023 "UPDATE" For some reason that couldn't be explained if you just put a loop around a characteristic with no break condition just telling it to loop "X" times just doesn't work I tried in 2021 & 2022 versions and it will only run once before giving you the same results "X" times without actually measuring again. Tried to get it to work with break conditions around the loop and just had no luck same result. Link to comment Share on other sites More sharing options...
