Convert ASCI cloud points into Mesh
Hello Natalia,
when you drag the ASCII point cloud into the software -> ASCII -> New Part, you can chose an import template in the next dialog. Depending on your data Pointcloud (Scanner) with or without normal should be fine. When the pointcloud is imported you can use this function ("Operations -> ... in the menu):
https://techguide.gom.com/en/article/cmd_pointcloud_polygonize_point_cloud.html
When the mesh is created, you can chose an alignment as usual.
Regards,
Nanno
