Units set by program?
I cant recall this happening on other Calypso installs, maybe I never paid attention to it.
When you use Calypso the last Units set are the Units it will use creating a new program.
When you save a program to specific Units shouldn't it open to those specific Units?
This particular Calypso install opens any program per the last Units used.
If I ran a program set to "Inch" mode, and later open a program set to "Metric" mode, the Units will convert to Inch. (And vice versa).
Calypso v2019
As far as I know, what you describe has always been the normal behaviour.
You can set the default units on a per program basis in the characteristics settings editor ("measurement plan editor characteristics") 1132_42248b26bd8f31f7be001f57b25f2691.jpg
This is available in Resources->Characteristics Settings Editor
Fun story:
Just the other day, I programmed a part in Inch mode using an offline programming station. After I imported it to the CMM station, I ran the program - The nominals were still in Inches, but the actuals were in millimenters. After I re-booted Calypso everything was fine. The other two programs that I wrote in Inches didn't have any issues... and I'm using the same level of Calypso on both stations (2020)
This is the problem.
If the program is in Millimeters and the last program opened is in Inches, the program opens in Inches. And vice versa.
It appears the program settings of Units is ignored.
I do not recall this from v2018 and prior.
