Probe Calibration Results Report
Hello,
I've used the Probing System Qualification to create a program to calibrate all of our probes.
I'm outputting the results to a pdf using the Default Report format.
By default, the results are going to C:\Users\Public\Documents\Zeiss\CALYPSO\workarea\results.
I want the results to go to a different location so I created the path shown in the screenshot.
This is working except for the file name is ".pdf" and the results overwrite each time.
I would like to have the program name (Probe Calibration) and a new file created each time the program runs.
Any ideas?
Is there an easier way?
Put the date and time in the File name.
Right now you're creating a file with no name.
getRecordHead("planid")+"_"+getRecordHead("date")+"_"+getRecordHead("time")+"_.pdf"
or
"static_file_name_"+getRecordHead("date")+"_"+getRecordHead("time")+"_.pdf"
I would recommend setting up a Name for all measurement plans using variables. This allows you to tick the box in any program and will create a file folder and file name according to your needs. You will never need to map anything else again.
This is actually a good idea; I'll be implementing this with our programs. Though with multiple machines, may want to add a serial number in there, or some sort of CMM identifier.
