Theoretcial Lines from Circle and Point
In this case it is best to use a 3D line. Secondly, do not use recall points but "Recall". Recalling the points is recalling the measurement points around the circumference of the diameters that you are measuring. Using Recall, you are recalling the measured diameter's center points. Doing this, your numbers should come out correctly.
