[Je...] Posted February 17, 2023 Share Posted February 17, 2023 . Hello. I am scanning a .030" thick stamped metal surface that is nominally defined as a plane but due to forming is more like a cone (see scan arrows below). Should I rescan this surface as a cone using the captured cone angle, or should the points interpolate correctly as is? . . Link to comment https://qualityforum.zeiss.com/topic/8560-scanning-a-quotplanequot-that-is-actually-a-cone/ Share on other sites More sharing options...
[Me...] Posted February 17, 2023 Share Posted February 17, 2023 This all depends on what the plane is to be used for. If you're capturing the form(Flatness), location, or alignment use a plane with outer tangential so you grab the high points. Or (and maybe a more preferred way) you can use a separate plane and recall only the outer ring points. If you're reporting the form/error of the surface, then I would report the cone angle and maybe the Z-Value of each diameter area so you can see the slope. Something like this, I would output into a color representation with scan lines drawn from outside towards the center. Link to comment https://qualityforum.zeiss.com/topic/8560-scanning-a-quotplanequot-that-is-actually-a-cone/#findComment-38098 Share on other sites More sharing options...
[Ja...] Posted February 20, 2023 Share Posted February 20, 2023 What is the distance from high point to low point? I don't know know much about other sensors but I have an XXT. The XXT will not compensate for surface variation when scanning if it's too bad. I don't know what the limit is. I would have to switch from scanning to single points and make sure the search distance is larger than the form error. You can adjust that under resources- feature setting editor- probing- search distance before nominal position. Link to comment https://qualityforum.zeiss.com/topic/8560-scanning-a-quotplanequot-that-is-actually-a-cone/#findComment-38100 Share on other sites More sharing options...
[Je...] Posted February 20, 2023 Author Share Posted February 20, 2023 Please sign in to view this quote. . That's a great idea, Andre. Here's what form deviation looks like using the original circle paths on the plane as well as a line profile of the center section: . . Link to comment https://qualityforum.zeiss.com/topic/8560-scanning-a-quotplanequot-that-is-actually-a-cone/#findComment-38102 Share on other sites More sharing options...
[Je...] Posted February 20, 2023 Author Share Posted February 20, 2023 Please sign in to view this quote. . Absolutely. Fortunately, our VAST Gold is capturing the points just fine, and I included the option for "search distance before nominal" to accommodate for the form error. . Link to comment https://qualityforum.zeiss.com/topic/8560-scanning-a-quotplanequot-that-is-actually-a-cone/#findComment-38104 Share on other sites More sharing options...
[Me...] Posted February 20, 2023 Share Posted February 20, 2023 Very colorful! I hope the info helped with the issue. Link to comment https://qualityforum.zeiss.com/topic/8560-scanning-a-quotplanequot-that-is-actually-a-cone/#findComment-38106 Share on other sites More sharing options...
