automatic polygonize with scripts
hello i build  a projects - uselly we work with kiosk but now we work from inspect pro.
can someone please do a video and upload somewhere about basic script - i want to build automatic project
right now i need to press Scan than select my part manuelly than polygonize than save pdf and than press mesh and save stl.
so i want a basic script that when i press the scan - it will continue automatic until the save, without i select the part and press polygonize.
1. Execute a measurement series within a project template
2. Cut out parts of the mesh outside of CAD and polygonize the mesh
3. Recalculate the project with the polygonized mesh as the actual master
4. Execute an export script which gives various required outputs (saved mesh, report pages, etc.)
thanks guys
Hello Eyal,
you can record those functions inside software with record functionality:
Scripting - Edit Script - New Script - "Record Button"
For deeper scripting requests, please use our Customizations forum
Best regards,
Jens Braun
