[Ja...] Posted February 7, 2023 Share Posted February 7, 2023 I read the overview of the Variable Strategy Editor in the operating instructions. Is there a video or other instructions that go into more detail as to how to set it up and use it? Link to comment https://qualityforum.zeiss.com/topic/8580-variable-strategy-editor/ Share on other sites More sharing options...
[Ma...] Posted February 7, 2023 Share Posted February 7, 2023 Is it something new or is that alternative strategy tab on features? Link to comment https://qualityforum.zeiss.com/topic/8580-variable-strategy-editor/#findComment-38402 Share on other sites More sharing options...
[Ja...] Posted February 7, 2023 Author Share Posted February 7, 2023 It first came out with 2020(?) and is located under the Measurement Plan tab. I've been so buried in work I just haven't had time to learn how to use it. Link to comment https://qualityforum.zeiss.com/topic/8580-variable-strategy-editor/#findComment-38404 Share on other sites More sharing options...
[Gu...] Posted February 16, 2023 Share Posted February 16, 2023 Have a look in the pdf Link to comment https://qualityforum.zeiss.com/topic/8580-variable-strategy-editor/#findComment-38406 Share on other sites More sharing options...
[Ja...] Posted February 16, 2023 Author Share Posted February 16, 2023 Thanks Guenter. I'll definitely take a look at it. Link to comment https://qualityforum.zeiss.com/topic/8580-variable-strategy-editor/#findComment-38408 Share on other sites More sharing options...
[Gu...] Posted February 16, 2023 Share Posted February 16, 2023 Jack, you can use the various ZEISS original strategies or create your own strategy. The easiest way to create your own strategy is as follows: Extras / Setting / Variable strategy editor: File open. Select one of the ZEISS originals. File save as <your name> Now the strategy can be adjusted individually. You don't have to start from the beginning In "Variable strategy assignment" you can now also use <your name> strategy Link to comment https://qualityforum.zeiss.com/topic/8580-variable-strategy-editor/#findComment-38410 Share on other sites More sharing options...
[Ch...] Posted February 16, 2023 Share Posted February 16, 2023 Not sure how other people are using it; but I've found that this works good if you have both XT and XTR heads. One program can now house both measurement strategies. Link to comment https://qualityforum.zeiss.com/topic/8580-variable-strategy-editor/#findComment-38412 Share on other sites More sharing options...
[Gu...] Posted February 16, 2023 Share Posted February 16, 2023 Different sensors is one possible application. Many users also use the rules to determine the measurement strategy for geometries, depending on the geometry itself. E.g. cylinder: how many paths and how fast to scan? If the CMM has the Navigator function, the Navigator strategy is probably the best rule Link to comment https://qualityforum.zeiss.com/topic/8580-variable-strategy-editor/#findComment-38414 Share on other sites More sharing options...
