backwards compatibility between versions
  • 4 months later...
no i didnt.. at least not yet. mostly because i need a solution to be able to swap all of our programs, and that seemed time consuming for close to 100 programs and counting.
After reading replies, does the software we would be saving it to ( ie' 5.8 2014) have to be installed on the same machine that the ver 2021 is on ? i just went thru the drop downs and saved program to a flash drive ... then moved to machine that had 2014 and tries to open it.
