[Du...] Posted October 13, 2022 Share Posted October 13, 2022 I have a fixture that has 8 identical parts in it. 5-8 are turned 180* around the Z axis from parts 1-4 so I've written a different program for them. The reasoning for this is because the fixture has the parts oriented like this. 5678 1234 In Auto-run I have 2 pallets with 4 parts. I know you can Ctrl + Select the pallets to run in sequence but I'd like to combine them if possible where the operator selects one button or click and it will load both programs to run. What's the best way to tackle this? Management wants us to use Autorun and single parts measured instead of programming the whole fixture in one program. Link to comment https://qualityforum.zeiss.com/topic/8612-combining-programs-in-autorun/ Share on other sites More sharing options...
[Ma...] Posted October 13, 2022 Share Posted October 13, 2022 I don't know of a one button solution for this. You can save sequences in the Autorun desk that both programs/pallets reside. Ctrl select the order you want to save and click the Sequence button on the bottom right of the screen select Save and give it a name. When you are in that desk with the saved sequence the Sequence button at the bottom right of the screen will be available. Click on that and then run. If you have multiple saved sequences in that desk you can select Load and select the sequence. This is the same thing you already know the only difference really is you don't have to Ctrl - select each time. Link to comment https://qualityforum.zeiss.com/topic/8612-combining-programs-in-autorun/#findComment-38630 Share on other sites More sharing options...
[Dy...] Posted October 14, 2022 Share Posted October 14, 2022 Might sound redundant but re-write the program to check 1 and the flipped 5 position only then pallet it across the others. Then in your report group the dimensions like (front) and (180) so you know what dims. goes with which part Link to comment https://qualityforum.zeiss.com/topic/8612-combining-programs-in-autorun/#findComment-38632 Share on other sites More sharing options...
[Du...] Posted October 18, 2022 Author Share Posted October 18, 2022 Ok. I'm trying to keep it simple for the operators but it looks like I'll have to show them the sequence feature. I'll just make this program on a desk link and have the background image to be a reminder to select both programs. Some of our operators aren't as computer saavy as others. Link to comment https://qualityforum.zeiss.com/topic/8612-combining-programs-in-autorun/#findComment-38634 Share on other sites More sharing options...
[RA...] Posted February 14, 2023 Share Posted February 14, 2023 Make the program Generate two alignment base systems with different names in the same program. one for orientation Important: you will have to do the manual alignment in both cases only from Calypso. Open auto run now create 2 palettes: 1 for the first 8 2 for the second 8 select the 2 palettes and you're done.autorun 180.jpg Link to comment https://qualityforum.zeiss.com/topic/8612-combining-programs-in-autorun/#findComment-38636 Share on other sites More sharing options...
