Unwanted part
You must edit the protocol, which means you will be creating a generic template. If you have administrative rights on your computer, this template could be moved to the folder where the template master so it become the new default. This folder is located at C:\Program Files (x86)\Zeiss\CALYPSO 7.4\PiWebReportingTemplates. This file will be overwritten any time you upgrade, so keep a back up copy in the same folder or some other place that you'll remember. Or get used to doing these steps every time you upgrade.
Select Page Structure tab at left.
Scroll down to Protocol footer
See below
