[SH...] Posted February 9, 2023 Share Posted February 9, 2023 How can I remove the unwanted part, shows in the arrow?? I have specific template,but sometimes it requires..IMG-20230209-WA0001.jpg Link to comment Share on other sites More sharing options...
[Ma...] Posted February 9, 2023 Share Posted February 9, 2023 If it's custom add and not from characteristic, then it can be done with condition - but we had use condition on text only - not for hiding Link to comment Share on other sites More sharing options...
[To...] Posted February 13, 2023 Share Posted February 13, 2023 You must edit the protocol, which means you will be creating a generic template. If you have administrative rights on your computer, this template could be moved to the folder where the template master so it become the new default. This folder is located at C:\Program Files (x86)\Zeiss\CALYPSO 7.4\PiWebReportingTemplates. This file will be overwritten any time you upgrade, so keep a back up copy in the same folder or some other place that you'll remember. Or get used to doing these steps every time you upgrade. Select Page Structure tab at left. Scroll down to Protocol footer See belowScreenshot 2023-02-13 075800.jpgScreenshot 2023-02-13 080246.jpg Link to comment Share on other sites More sharing options...
[Th...] Posted February 13, 2023 Share Posted February 13, 2023 As an alternative to what Tom posted, you can disable the footer with a dedicated checkbox. Link to comment Share on other sites More sharing options...
