Report Header Parameters Global Setting?
Is it possible to set or configure the Report Header Parameters globally for all measurement plans at once? Does CALYPSO (running version 7.4) still use the userfields.ini file now that the Userfields Editor has been implemented and if so, is there a way I can modify it so all measurement plans are using the same parameters?
I did find this older thread but there didn't seem to be any resolution posted.
viewtopic.php?t=720&hilit=report+header+parameters
What I ended up doing is created a few Templates with all my settings pre-defined.
Works great for all new programs.
For legacy programs, I have to load the protocolheader file and the PiWeb template manually, which is a one time deal.
You can also open a template with all the settings pre-defined and copy past all the Features/Characteristics to the new program, save as and move the original to a history location.
Rick - We do have Template programs configured but unfortunately there are still over 1000 legacy programs that I need to update so I'm looking for an easier way. I've been successful mass updating other program settings with a nifty little workaround but it appears that this particular setting poses a different set of issues.
Another approach I think would work would be to create an additional output field in the "merge_chr.txt" file, does anyone know how to make the necessary modifications to achieve this?
