Automatic RDS Stylus Angle
I'd like Calypso to automatically assign an appropriate RDS stylus angle from the feature but I get an error message. The error message is saying there is no associated angle. The stylus angle search is set to 10° and the appropriate angle would be A30B-90. I get the error whether I select Auto1 or Auto2.
Just to add a bit of clarity to my response. I was referring to the automatic stylus assignment routine found under Resources > Stylus System. After I took another look at the OP's picture, I noticed the "Shaft away /Shaft along" area was circled, so I don't know if I was on the same page.
If you're using RDS/CAA and you're in the RC-List window, you can select a feature and have it find the appropriate probe angle for the feature.
Screenshot 2023-02-10 085123.jpgFetching info...
