[Ca...] Posted April 27, 2022 Share Posted April 27, 2022 I have a 3d scan of a pipe. And one check I need to perform is to calculate the cross sectional area of the inner profile (Highlighted Red). And perform this check on both the CAD geometry and the actual geometry. I have managed to create a surface based on the cross section but cannot find a way to show the surface area of this. Note - The cross section in this example is circular, but I will also need to do the cross sectional area on more complex shapes. And so measuring the diameter of the circle will not be sufficient. Link to comment Share on other sites More sharing options...
[Na...] Posted April 27, 2022 Share Posted April 27, 2022 Hello Caleb, you can create a single section only from the inner circle, apply referenced construction or another measuring principle which is suitable. Then the nominal section can be directly checked for "Area" in I-Inspect. It works best with closed sections (no holes or missing data). Regards, Nanno Link to comment Share on other sites More sharing options...
[Ca...] Posted April 27, 2022 Author Share Posted April 27, 2022 Thanks Nanno, One reason I created a fitting polynom surface from my actual section was because there will be some gaps in the section curve. I've tried to use the 'Close Gaps' tool for surfaces but its not identifying the gaps that I need to fill. Polynom surface seems to have filled in the gaps suitably. But then doesn't give the option to display area. Is there an alternative way to fill in gaps on a section/ curve? A curve tool equivalent to mesh bridge would be very useful. There are some situations where filling in gaps in the mesh before will not be possible. Alternatively can I create a curve based on the perimeter of my polynom surface? Link to comment Share on other sites More sharing options...
[Na...] Posted April 27, 2022 Share Posted April 27, 2022 Hello Caleb, if you want to have control over the closing, you can chose Operations -> sections -> close gaps. If you check an open section for area the gaps are closed in the background. Regards, Nanno Link to comment Share on other sites More sharing options...
