[Je...] Posted February 7, 2023 Share Posted February 7, 2023 . Have any of you patterned a 2D_Curve in Calypso? If I am wanting to evaluate profile of several instances of a curve, each one to itself and not to other datums, will the nominals for each instance be defined by the first instance of the feature or by the offset defined in the pattern or something else? Wow... I worded that question very confusingly. What I mean is: . . Link to comment https://qualityforum.zeiss.com/topic/8678-can-i-pattern-a-curve/ Share on other sites More sharing options...
[Ma...] Posted February 7, 2023 Share Posted February 7, 2023 Never tried - but in some cases it can be benefitial. Link to comment https://qualityforum.zeiss.com/topic/8678-can-i-pattern-a-curve/#findComment-39034 Share on other sites More sharing options...
[Je...] Posted February 7, 2023 Author Share Posted February 7, 2023 . It appears that the nominals for each instance are considering the offset I set in the 1D linear pattern. This was actually a fairly quick way to evaluate a profile at multiple sections. . . Link to comment https://qualityforum.zeiss.com/topic/8678-can-i-pattern-a-curve/#findComment-39036 Share on other sites More sharing options...
