PiWeb Conversion Inch to Metric
Hello everyone,
I was wondering once I have a part ran and have a report and it displays as a PDF. Can the tolerances be changed from Inches to Metric on that PDF? Or do I need to rerun the part in metric tolerances?
Thanks,
Lou
  • 2 weeks later...
Hi Lou
You will need to run the part program again in metric to display millimeters on the PDF. If you have measured points turned on in Results to File for the measurement plan, run subsequent measurements of prior data so you don't have to re-measure the part over again.
Best regards,
Joseph Harter
