[Da...] Posted February 2, 2023 Share Posted February 2, 2023 I am creating a program from a stp model, when my probe completes a circle it doesn't retract from the hole, it is trying to move thru the part and crashes in the diameter while it is moving to its next feature. 🫣 Any suggestions? Link to comment https://qualityforum.zeiss.com/topic/8724-probing-issues/ Share on other sites More sharing options...
[Ke...] Posted February 2, 2023 Share Posted February 2, 2023 Step 1 - look in your strategy for a rogue point (that does not belong) Link to comment https://qualityforum.zeiss.com/topic/8724-probing-issues/#findComment-39302 Share on other sites More sharing options...
[Ju...] Posted February 2, 2023 Share Posted February 2, 2023 Also, double check that the clearance planes are set to the correct approach axis. (-X, +X, etc.) Link to comment https://qualityforum.zeiss.com/topic/8724-probing-issues/#findComment-39304 Share on other sites More sharing options...
[Ke...] Posted February 2, 2023 Share Posted February 2, 2023 Justin and Keith both have excellent suggestions. For more information, what version of Calypso are you using? Are the features in question using primary clearance planes (CP) or subclearance planes(SCP)? Link to comment https://qualityforum.zeiss.com/topic/8724-probing-issues/#findComment-39306 Share on other sites More sharing options...
