problems with surface profile in freeform
hi, sorry for the novice question. but i'm very new to curves and freeform
let me try and explain as simple as possible.
i'm programing on a 3D model
i used alot of 3d curves and spacepoint
i need to measure surface profile on certain places.
my idea was : "freeform surface" ---- "recall feature points" ----- select the spacepoints and/or curves i need
now this is where i start scratching my head ; the "actual's" on that freeform come out anywhere from 0.0007 to 2.5mm, where they should be 0.0000....
if i recreate the freeform and measure everything within it , it does come out 0.000
does freeform not preform correctly using recall feature points?
I think from what i've read on forum, that planner gives some results - not just ZERO. But 2,5 is strange.
Are you working with model? I have never recalulated curve to FF - I just recalled points and selected face on model if needed.
How looks deviations when you turn on graphical evaluation? It should show you where is that big deviation.
If you are simulating measuring then NO you will experience some data NOT zeroes.
If you don't have measured data, then your results will be zeroes.
