[st...] Posted January 27, 2023 Share Posted January 27, 2023 hi, sorry for the novice question. but i'm very new to curves and freeform let me try and explain as simple as possible. i'm programing on a 3D model i used alot of 3d curves and spacepoint i need to measure surface profile on certain places. my idea was : "freeform surface" ---- "recall feature points" ----- select the spacepoints and/or curves i need now this is where i start scratching my head ; the "actual's" on that freeform come out anywhere from 0.0007 to 2.5mm, where they should be 0.0000.... if i recreate the freeform and measure everything within it , it does come out 0.000 does freeform not preform correctly using recall feature points? Link to comment https://qualityforum.zeiss.com/topic/8760-problems-with-surface-profile-in-freeform/ Share on other sites More sharing options...
[Ma...] Posted January 30, 2023 Share Posted January 30, 2023 Working on planner or real part? Link to comment https://qualityforum.zeiss.com/topic/8760-problems-with-surface-profile-in-freeform/#findComment-39446 Share on other sites More sharing options...
[st...] Posted January 31, 2023 Author Share Posted January 31, 2023 planner Link to comment https://qualityforum.zeiss.com/topic/8760-problems-with-surface-profile-in-freeform/#findComment-39448 Share on other sites More sharing options...
[Ma...] Posted January 31, 2023 Share Posted January 31, 2023 I think from what i've read on forum, that planner gives some results - not just ZERO. But 2,5 is strange. Are you working with model? I have never recalulated curve to FF - I just recalled points and selected face on model if needed. How looks deviations when you turn on graphical evaluation? It should show you where is that big deviation. Link to comment https://qualityforum.zeiss.com/topic/8760-problems-with-surface-profile-in-freeform/#findComment-39450 Share on other sites More sharing options...
[st...] Posted January 31, 2023 Author Share Posted January 31, 2023 again, excuse my stupidity 😃 the model is the "perfect" shape so every surface profile i measure should be 0.0000 right? Link to comment https://qualityforum.zeiss.com/topic/8760-problems-with-surface-profile-in-freeform/#findComment-39452 Share on other sites More sharing options...
[Ma...] Posted January 31, 2023 Share Posted January 31, 2023 If you are simulating measuring then NO you will experience some data NOT zeroes. If you don't have measured data, then your results will be zeroes. Link to comment https://qualityforum.zeiss.com/topic/8760-problems-with-surface-profile-in-freeform/#findComment-39454 Share on other sites More sharing options...
