Looping a feature
I know that Calypso does this already. If you input an incorrect
speed for example, Calypso will re-measure the feature with the
correct speed. So, it sounds like it's possible? PCM/Condition?
I'm with you on the conditional statement. I recall seeing something years ago tied to the sigma value of the feature but don't know where to start.
Probably something like this (PCM). Can't add anymore to that other
than you have to start somewhere. This is as good a place as any.
repeat
until i>10
I've rarely looped a feature, but many alignments. My thought process is that if the sigma values are high, that I have either an alignment issue, a form issue, or a probing issue, so I take care of that prior to remeasuring the feature by using more alignments, different probing strategy, cleaning the part, etc. Looping recalculates and iterates to solve a fit based on the parameters input. That basically affects how the machine moves relative to the features being measured. So, I don't see much use for it if I've already set those things up properly.
I will loop features to test repeatability of the machine on occasion. But that's more of a calibration/verification process. And I will loop cast features or any unstable features that are used in alignments.
Thanks for bringing this topic up. I've wondered about the same thing, and I don't remember feature looping being covered in training, only alignments.
I have done the conditional statement. I used it to measure or skip a secondary feature. I'm not sure how you could do this on itself without a circular argument issue. For example, a circle has bad form, or a short cylinder has vector issue, the condition with use another measurement strategy or evaluation. That additional information serves as a redundancy.
There also is the option of remeasure on the reporting end if it fails..
I hit the "PCM not available" block so you'll need help on the syntax and operators but you can use it in strategy or characteristic side.
