Bushing Dia + MMC
My question is regarding a bushing diameter , using max inscribe element + mmc .
The first line represents the value of true position + (mmc) the bonus tolerance , correct ?
The second line represents the value of true position without the mmc correct?
Bonus tolerance of .0385 is applied to this .
Am i understand this correct?
1.jpgFetching info...
Yes the first line is your actual position result, with the MMC bonus added to your tolerance. The 2nd line is a statistical percentage related to the position on the first line. Read this thread and it should help explain the calculation.
viewtopic.php?t=10880
I agree 100%.
I was just frustrated because I still feel like my main gripe about the .M was completely overlooked and the same answer about why you need .M was posted.
How about Zeiss making a change to the readout that says " percentage of tolerance used with bonus" instead of just letting us argue about it's meaning for 3-4 pages of discussion on the forum!!!! The read out isn't clear, so clarify it! UGH.
