ATOS "Acquisition parameters" default setting for reference points
In the ATOS 2020 scanning software, is there a way to change the " Acquisition parameters" default settings for “Reference point identification”? We never, ever, ever want it to be “High Accuracy”. We always want it to be “More points”. Yet “High Accuracy” is the default. Can that be changed somehow?
Hello,
The recommended way to use user-specific default settings for projects is to use project templates:
  • Create a new project
  • Specify the appropriate Scanning Template and reference point settings for your application
  • Save the project as a project template
  • Then, choose "Project templates" instead of "New project" in the Home screen
You can have multiple project templates, each for another application or measuring object type.
I hope this helps!?
Regards
Matthias Aalto
