Duramax Stylus System Holder
I recently added a Single Stylus holder to our Duramax on the left side of the rail and now when homing the CMM after a restart the system it is wanting to hit the stylus holder when homing. Can the home location be changed? Is there a safety zone for the stylus holders?
Before or after? If before, just jog the Z up higher before homing. If after, edit the values on the homing screen to move out further in -Y and/or reduce the -Z value.
You might also trying to see if you can slide all of the holders to the right a bit. I usually will move the machine to X490 on the joystick controller readout and line up the right-most pocket of the right-most holder to maximize the space.
