How to change line profile plot error scaling
one program has several line profile graphic plot on pi-web report. but the error scaling is different when print out. can it be changed and given a fix ratio? thank you in advance.677_e526c98fcf806e8d0e623de4239f4df4.jpg
Undefined means Calypso will set magnification automatically and randomly. You can type in any value that you want. I typically pick one number for all plots of a similar view so users will get the same perspective from plot to plot.
  • 4 weeks later...
Tip:
Instead of moving the slider, you can also enter a number in the field marked in yellow. The entered number could then be the superelevation factor in the inspection characteristic if you do not want to use the automatic plot superelevation.
