Looping through Directory
Hello Community,
i am new to PCM but i know C# and Visual Basic as a programming languages. We got some part families so i wanted to create something like a user interface were you can select between different partnames.
I planned to save the .Para files in a directory within the Actuall Inspections Directory.
filespath = getActualInspectionDir() + "\files\" -> this will give me the correct Path
Now i want to loop through every File in this Directory and store the names in a list. Later the worker can pick one of the names in the user interface and it will load the picked .para file for the CNC Run.
In C# i would use foreach.
foreach(var item in myDictionery)
Filename = Filename + " " + item.name;
Is this possible within PCM ?
Thanks, Michael
https://qualityforum.zeiss.com/topic/8902-looping-through-directory/
Thank you Michael for asking this question and thank you Phillip for sharing this possibility.
I find this AMAZING!!!
I probably can't and won't describe how we used to work around for this problem.
And this solution is so much better!
I adapted it a little bit for my use and i think this is also what Michael asked for.
filepath = getActualInspectionDir() + "\files"
dirContent = getParameterNamed(filepath.asFilename).directoryContents
ListPara = "inquireList(" + qm() + "Type auswählen" + qm()
for i = 1 to dirContent.size
	display(getParameterNamed(dirContent,i))
	N[i] = getParameterNamed(dirContent,i)
	ListPara = ListPara + ",N[" + i + "]"
next i
ListPara = ListPara + ")"
ItemName = getParameterNamed(ListPara)
readPCMFile(ItemName)
  • 4 months later...
An other idea with the selectFileDialog?
// selectFileDialog([path (or path symbol such as directoryPath)[,Filter[,Dialogtext[,Return mode]]]]
//For more option, please check the PCM manual (seach for "selectFileDialog")
PATH="C:\temp\"
FILTER="*.para"
DIALOG="Please select file"
MODE=0
SELECTION=selectFileDialog(PATH,FILTER,DIALOG,MODE)
  • 2 weeks later...
Wouldn't this be the simpler way to do it?
Presetting's
clearCAD()
dir = getActualInspectionDir()
Part_Number = inquireList("Which part number are you inspecting?","13-12345","13-23456","13-34567")
selectCase Part_Number
case "13-12345"
readPCMFile(dir + "\13-12345.PARA")
loadCADFile(dir+"\13-12345.sab")
case "13-23456"
readPCMFile(dir + "\13-23456.PARA")
loadCADFile(dir+"\13-23456.sab")
case "13-34567"
readPCMFile(dir + "\13-34567.PARA")
loadCADFile(dir+"\13-34567.sab")
endSelect
.PARA file with variables is in the program folder.
  • 3 weeks later...
An example without "if" or "select case"
For more variants, just expand T1, T2,T3...
clearParameter() //Clear all Parameter
clearCAD() // Deletes the loaded CAD model
MeinLogFile = "C:\temp\PCM\log.txt" // My Log File
aSep = " | " //A separator for my log file
PathInspection = getActualInspectionDir() //Here is the measurement plan
FileExtension = ".para" // File extension
Path = PathInspection +"\PCM\" // There is a subfolder PCM in the measurement plan. Here are my PCM files
//------A selection list of variants---------
T0 ="Please select "
T1 = "small ring"
T2 = "middle ring"
T3 = "big ring"
Variante = inquireList(T0,T1,T2,T3) //Query and remember the variant
PCMFileName = Path + Variante + FileExtension // Build complete path structure together
display(PCMFileName) //Show complete path structure
addToFile(MeinLogFile,"This variant was selected: ",PCMFileName,aSep, dateAndTime()) //Write path structure and date to log file
if fileExists(PCMFileName)
message("File is there: " ,cr(),PCMFileName ,cr()," ==> CNC process is started")
readPCMFile(PCMFileName) //read in the parameter file
CADFile = Path+"CAD" + Variante + ".sab"
if fileExists(CADFile) == true
loadCADFile(CADFile)
endif
else
// There is no parameter file !!!!
message("There is no parameter file !!!! " ,cr(),cr(), PCMFileName) // output message
cncBreak() // Switch traffic light to red
endif
// Write information in the report header
// setRecordHead("drawingno",ZeichNr) //Write the drawing number
// aktiviere die Datenbankvariantensteuerung ab CALYPSO 2022
// activate the database variant control from CALYPSO 2022
// Prepare / Results to File / PiWeb reporting / Configuration /Separate Database for each variant
setRecordHead("variant", Variante) // Write the variant
  • 3 years later...
