XXT star probe aligment
Hello,
I have always worked on a Contura but now have a Duramax I am setting up. I am trying to replicate some of the Contura stylus systems using the non threaded star cube and M3 clamping adapter. Problem is that if I get the Y probes level, the X probes become tilted and vice versa. Is there a trick to get all 4 probes level? The cube seems to be flush with the adapter and extension. I qualified one of the non level stars and the sigma is below 0.001mm with a low 20% probing dynamic.
Also concerned that the non threaded star cube can shift since its only being held in place with the clamping adapter underneath.
Attached is a picture of the setup.
Thanks!
