Height over pin
I have not tested this but I would try to measure the groove with 2 lines and create a tangent construction with the correct diameter. Then measure the distance with Caliber Distance. I think that would work.
I just remembered how I did this before. Measured 2 planes. Create 2 Plane with Offset constructions, using radius of pin for offset.
Then I created a Theoretical plane with a space axis parallel with groove. I used a Y value to control where I wanted the height to be checked.
Next, I created an intersection construction using the 2 Planes with Offset and the Theoretical plane to create a point.
Then, a Result Element to add the radius to the Z value of the point.
Could make several theoretical planes to show the height in several places.
