Similar Parts same measurement technique
Hi all, I haven't really been able to find a great answer on this but we have a product with, let's say 100 variations, and the style doesn't change but the width/length/height & a few diameters change from part to part. We're looking for a quick way for operators to come up and type in the varied dimensions and have the program be able to run. I know there are ways to do this with PCM, but we do not have it nor is it in the budget to get it. Are there any tips & tricks others can recommend to be able to do this?
FYI, I'm relatively new to ZEISS but ran another brand of CMM for years, so I understand capabilities but not always the 'how'.
Miniplans are easiest way. But this can bring copies of features. If noone will bring better solution i'll try some conditions with miniplan or input parameter. I don't have PCM either
Well, that's exactly what PCM was made for, so it's no surprise Calypso doesn't provide an easy means to accomplish this another way 😉
If it's not too many parameters, you could define a number of custom protocol header fields and input the values there. In the features you'd insert a formula like getRecordHead("u_field1") to get the value. Thinking about it, I guess it would rather be val(getRecordHead("u_field1")) to turn it into a number or you might get an error.
I never tried if this would work and it has a lot of drawbacks aside from being tedious, but hey, you asked for it...
I will add to Norbert's answer. I've used "ord" to get true/false and multiply with needed number.
So i had: ord( valA = 1 )*25+ord( valA = 2 )*26+ord( valA = 3 )*27 - based on valA was result as 0+26+0
( written from head, so maybe it's written wrong, but here is idea )
Hey Josh. I totally understand the budget constraints challenge. I wish PCM functionality were provided as default in Calypso. I wonder if there is a way to argue Return on Investment from the programming time saved and get your company's finance people to make a PCM purchase happen.
I'd be excited to hear any updates on progress you make using Norbert and Martin's ideas for programming.
Same. I'm used to the other CMM software being inclusive of PCM type features. But they had a totally different business model and I honestly like the functionality of Calypso way better anyway. Everything comes with a cost!
Yeah, PCM might be an investment down the road and i might be able to run it through with ROI but might have to wait a bit.
Anyway, I tried out the report header variables and it does seem to work! I just had to figure out how to do it. The main issue i ran into was pushing the variables to the element. (Right-click in the field and select "formula" for future reference). Now i just need to get with Design to see how many variables we'll need and hopefully not have to think too hard on alignments 🤣
