GD&T Question, ISO
I've been asked to assist a sister facility in a different country, this drawing is ISO. I'm completely unfamiliar with ISO. What's not shown in that drawing is that hub is stepped.
Datum B would be the 85mm diameter, which is the larger step at the base of the hub.
What is Datum D? I have some guesses. It looks like it might be specifically talking about a line segment along -B-. It only calls out one on the drawing.
Then item 8, the symmetry of B, parallel to D? 3535_50d87f8f3e04381fef3aadd424288511.png
Is it this simple? Done a number of times around the hub? 3535_832a6646614793b0eefcee530673ca29.png
https://qualityforum.zeiss.com/topic/8988-gdampt-question-iso/
This is so confusing.
8 B|Sym - this should tell you direction of tolerance band for parallelism. But i was thinking, that it sould be parallelism or perpendicularity sign - not symmetry.
Base D should be only point - center of circle and base B should be center of cylinder anyway.
Edit - seems like base D is compound of points
https://qualityforum.zeiss.com/topic/8988-gdampt-question-iso/#findComment-40856
Okay so then is this a case of poor drawing resolution because stepped end of the hub which has a diameter of 84.5mm(0.5mm smaller)? 7,8,9 are actually referring to that, not B.
That starts to make more sense if that's the case... I think.
This is a cut of the model that actually shows the step. 3535_3971665fe7e39e035e3f9ab36bab651b.png
https://qualityforum.zeiss.com/topic/8988-gdampt-question-iso/#findComment-40860
Thank you! That confirms what I ended up finding. Not being well versed in ISO those "Intersection plane indicators" are a bit confusing to me. Trying to get the management to buy the standard.
Now, in Calypso - how would you measure #7,8?
I measured the Cylinder that is B, and used it to create a coordinate system as the Spatial and 2 directional origins. Then measured -D- as 4 2d lines around the surface of that cylinder in that coordinate system.
Reported the straightness of those lines.
And reported the Parallelism of Line 1 to Line 3, 2 to 4, 3 to 1 and 4 to 2, then reported the max.
My understanding of this is that it's very similar to the Parallelism of surface lines on Pg. 71 of the cookbook.
https://qualityforum.zeiss.com/topic/8988-gdampt-question-iso/#findComment-40868
