Command is not active
This code worked previously for closing an ATOS session; now it is erroring
gom.script.sys.exit_program ()
Error GAPP-0003
The chosen command is inactive
Anyone know what could have changed?
This is the exact code the script generator produces for ATOS 3d capture.
Hello Lance,
the command is disabled if you start the script from the script editor. It should close the session when you run it from the menu.
Regards,
Nanno
