[La...] Posted May 3, 2022 Share Posted May 3, 2022 This code worked previously for closing an ATOS session; now it is erroring gom.script.sys.exit_program () Error GAPP-0003 The chosen command is inactive Anyone know what could have changed? This is the exact code the script generator produces for ATOS 3d capture. Link to comment Share on other sites More sharing options...
[Na...] Posted May 4, 2022 Share Posted May 4, 2022 Hello Lance, the command is disabled if you start the script from the script editor. It should close the session when you run it from the menu. Regards, Nanno Link to comment Share on other sites More sharing options...
