[Da...] Posted December 13, 2022 Share Posted December 13, 2022 Is there a way to turn on table file for all programs at once? Will I have to turn them on individually by program or is there a global type of setting? Link to comment Share on other sites More sharing options...
[Ma...] Posted December 13, 2022 Share Posted December 13, 2022 It's program based. Should be done with batch script ( like LUA and others ) to edit this in inspset or inspection file. Link to comment Share on other sites More sharing options...
[To...] Posted December 13, 2022 Share Posted December 13, 2022 If you use a template program, you can set it to be on. While we're talking, I think merge files should be program specific, too. i.e. program name_merge_chr.txt program name_merge_fet.txt program name_merge_hdr.txt Link to comment Share on other sites More sharing options...
[Ma...] Posted December 14, 2022 Share Posted December 14, 2022 It is stored in "inspset" file "#resultToQdasFile ' ->' false)" Here are samples: // qdas forced ON #resultToQdasFile ' ->' true) #( #resultToQdasFileDialog ' ->' #on) // qdas choosable on CNC #resultToQdasFile ' ->' false) #( #resultToQdasFileDialog ' ->' #cnc) // qdas turned OFF #resultToQdasFile ' ->' false) #( #resultToQdasFileDialog ' ->' #off) Locate and rewrite that according samples by some automated task to do changes to all programs. You might need to custom name of files - should be in same file, just search for it. Link to comment Share on other sites More sharing options...
