How to choose "All Characteristics"
Here is what I have so far. How do I offer the choice of running the full program, without creating a mini plan for it?
Thank you in advance.
LN = getRecordHead("order")
clearCAD()
dir = getActualInspectionDir()
Run=inquireList("Which mini-plan do you wish to run?","Plan-1","Plan-2","Plan-3")
setRunID(Run)
Part_Number = inquireList("Which part number are you inspecting?", "13-00188", "13-00189", "13-00190")
selectCase Part_Number
case "13-00188"
readPCMFile(dir + "\13-00188.PARA")
loadCADFile(dir+"\13-00188.sab")
case "13-00189"
readPCMFile(dir + "\13-00189.PARA")
loadCADFile(dir+"\13-00189.sab")
case "13-00190"
readPCMFile(dir + "\13-00190.PARA")
loadCADFile(dir+"\13-00190.sab")
endSelect
There are a few ways.
With PCM, I believe you can addCF (characteristic), however I don't know the concatenated code for 'all characteristics', I'll do some research.
If all characteristics are the same for all parts, do you need to specify what to run?
Other than I would just use mini-plan either for all characteristics or for each P/N.
There are PCM options for mostly everything on the start run screen. I will get back to you if noone else solves it first.
Good luck.
EDIT : getCFNames() will return a list of all characteristic names. Perhaps somehow write this to a variable?
ALLCHAR = getCFNames()
AddCF = ALLCHAR
Hmm, interestingly enough, the code I just posted seemed to work offline if put in the presettings of your plan (and then I chose a 1 characteristic mini plan to run - and it ran the whole program)
However I do believe there is a one-liner that may be simpler.
I'll dig around a bit further.
For a while I was using setRunID() with no argument to do this.
I honestly forget why I stopped, I think it worked in some versions but not others (I have everything from 4.0 to 2020 I need to make things compatible with). Or maybe it behaved differently with AutoRun vs when being used without.
I elected to just make a FullProgram Miniplan, the only annoyance is if I add a feature I have to edit the MiniPlan. For a while I used the "Form from Characteristic Groups" option and that worked well too. But I found it was easier to just Ctrl + A, Form Miniplan and overwrite the FullProgram one when changes were made.
`setRunID("complete")` is the full plan without mini-plan structuring
If you set the mini-plan to a group of characteristics, any time you add a characteristic to that group, it is included in the relevant mini-plan. IE - In your situation, if you put all characteristics in a group, the mini plan applies to all. If you want to remove an item from the mini-plan, rather than edit, all you have to do is drag it out of the group.
  • 2 weeks later...
This works.
Run=inquireList("Which mini-plan do you wish to run?","Plan-1","Plan-2","Plan-3","Complete")
setRunID(Run)
if Run=="Plan-1","Plan-2","Plan-3" then setRunID(Run)
else ("All Characteristics")
endif
Thanks for the suggestion, Tom!
I noticed that whichever item you choose in the run window (All Characteristics, Current Selection or the Mini-Plan), that choice shows up on the PiWeb Report in the field Run. So, I thought maybe that might be a valid name.
My apologies. I was sure that I've used setRunID("complete") before and I ran a program without a mini-plan and 'message(getRunID())' returns "complete" in 7.2. I didn't test setRunID to verify in this instance however. Apologies.
