[Ri...] Posted December 2, 2022 Share Posted December 2, 2022 Is there any information on the Bolt Pattern for a Prismo 12/18/10? I need this info for layout work for automated fixturing. Any help is appreciated. Link to comment Share on other sites More sharing options...
[Da...] Posted December 2, 2022 Share Posted December 2, 2022 Please sign in to view this quote. Try to go trough -> https://portal.zeiss.com/download-center/documents, Category - CMMs Link to comment Share on other sites More sharing options...
[Ri...] Posted December 2, 2022 Share Posted December 2, 2022 You can also access the 3d model of the machine itself. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 2, 2022 Author Share Posted December 2, 2022 Please sign in to view this quote. 1. I don't have the machine, a customer will get it soon. 2. Can you make measurements from the model? 3. I sent you a message. Link to comment Share on other sites More sharing options...
[Je...] Posted December 2, 2022 Share Posted December 2, 2022 Nearly all recent Zeiss CMMs have a 200mm bolt space pattern using an M12 bolt. Exception is Duramax which is 100mm and M10. First bolt on the Zeiss Prismo "should" be X +162.5mm, Y +221.5mm from Front Left corner of granite. There are minor variations depending on Ultra/Prismo/Fortis etc. Link to comment Share on other sites More sharing options...
[No...] Posted December 5, 2022 Share Posted December 5, 2022 Please sign in to view this quote. Starting with Calypso 7.2 (latest) the machine models have been changed to the proprietary *.vff format. So if you still have an older copy of Calypso installed, better keep a copy of the cad-components folder.... Link to comment Share on other sites More sharing options...
[Ri...] Posted December 5, 2022 Share Posted December 5, 2022 Please sign in to view this quote. I know. 🙁 Link to comment Share on other sites More sharing options...
[Ri...] Posted December 5, 2022 Share Posted December 5, 2022 Please sign in to view this quote. Yes, you can take measurements from the model. It is an actual model. Thanks. Link to comment Share on other sites More sharing options...
[Je...] Posted December 5, 2022 Share Posted December 5, 2022 Please sign in to view this quote. 6.8 was the last version with machine CAD models that could be opened with standard CAD software. 7.0 has VFF files. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 5, 2022 Author Share Posted December 5, 2022 Please sign in to view this quote. Unfortunately the models do not have bolt holes in the granite surface. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 5, 2022 Author Share Posted December 5, 2022 Anyone have the X and Y axis hole count? My Contura is 5 x 8. I was hoping this was general knowledge and available. Its killing time for a fixture design. Link to comment Share on other sites More sharing options...
[Ri...] Posted December 5, 2022 Share Posted December 5, 2022 Please sign in to view this quote. I just checked and they didn't model the holes for whatever reason. Check the attached screenshot. Thanks. Link to comment Share on other sites More sharing options...
