measure Effective and Actual Circular Tooth Width
For splines, use spline gages and measure dimension over/between wires.
For gears, measure actual tooth thickness with wires, span, or radius over one wire. Effective tooth thickness can be measured with a master gear either in a double flank tester measuring center distance, or in a roll tester measuring backlash.
