Mini Plan location
How do I copy the mini plans from one program to another?
I see the list of mini plans under the RUN folder but that does not copy the actual mini plans.
thank you
  • 2 weeks later...
Martin, thank you
Yes they are mixed in the inspection file, but I don't know how to sort or separate them.
I do not want to copy the whole inspection file since I did copied most of program into another program name.
I want the mini plans since there were several but, I don't want the whole inspection file.
There is a list of mini plans under "runs" folder but, not sure what that is for. You can delete names or add them but it does nothing to the actual mini plan list.
Hopefully someone will know how to do this.
thank you
The files in "runs" are identifiers used elsewhere and not the actual mini-plans. The mini-plan characteristic list itself is saved in the inspection file and cannot be migrated to another inspection plan.
Lori, how many characteristics are in each mini plan that you want to copy? Could you just define them again in the new program by selecting the characteristics required and go to Plan>Miniplan>Define. You can keep the same miniplan name as the other program to minimize confusion for other operators or disrupt any PCM. Depending on the number of characteristics, it will only take a few minutes.
