Measurement Plan Editor Characteristics
Hi all,
I was wondering if any of you gurus could lend me a hand. I was wondering If there is a way to edit the characteristic comments within the measurement plan editor characteristics? Is there something I can toggle on to make them editable?
When going through our old programs and updating the characteristic numbers, print locations and characteristic types. Sometimes there are other characteristic numbers associated with the characteristic that we add to the comments(not the programmer comments, the characteristic comments). It is quite cumbersome to updated all of this within the measurement plan editor characteristics and then have to go through each characteristic comment in the characteristic tab and change those too.
Holy hell did I just say characteristic too many times.
Regards,
https://qualityforum.zeiss.com/topic/9154-measurement-plan-editor-characteristics/
  • 1 month later...
  • 10 months later...
Mike, Can you post the text from the ini file for these ? I pasted the example from the manual but I'm not seeing the variable in PiWeb to add them in my report. Maybe post that snippet from your PiWeb template too.. I can assign the attribute in the program but cannot find it on the PiWeb side.
  • 3 weeks later...
  • 2 weeks later...
These are User Attributes, setup via Resources>Design custom report> Editor for characteristic attributes. They get saved in the userattributes.ini file located C:\Users\Public\Documents\Zeiss\CALYPSO\data\config.
Below is how the ini file reads:
REM ...\Users\public\documents\zeiss\calypso\data\config
REM By convention the userfield names begin with "u_"
[u_char_num]
name=Char Number
selectiveList=false
editable=true
runMode=true
protocolOutput=true
REM Now defining the userfield named u_print_loc
[u_print_loc]
name=Print Location
selectiveList=false
editable=true
runMode=true
protocolOutput=true
REM Now defining the userfield named u_characteristic_type
[u_characteristic_type]
name=Char Type
selectiveList=true
selectiveListValues=u_characteristic_type_valueList
editable=true
runMode=true
protocolOutput=true
[u_programmercomment]
name=Programmer Comment
selectiveList=true
editable=true
runMode=true
protocolOutput=true
[Fieldnames]
u_char_num
u_print_loc
u_programmercomment
[u_characteristic_type_valueList]
1=Ref
2=Standard
3=Key Char
4=Critical Char
5=Manual
