Differences between meshes in located points
How can I measure the difference between a mesh or CAD and a second mesh at certain points selected in each of them? That is to say, to see the variation between the points when superimposing the meshes.
Hi,
with a Professional License you should use a trend project: Each mesh is one stage.
The evaluation is done on a discrete nominal point (which you can construct beforehand) or with a Surface deviation on CAD.
Regards,
Bernd
