[Mi...] Posted November 11, 2022 Share Posted November 11, 2022 Calypso7.2 does not show the virtual machine for simulations. For example; in the company where I work we have 3 Conturas G2 with RDS, so we use the planner for programming, but the Planner is limited because you can't get a complete simulation due to the lack of the virtual CMM. Link to comment https://qualityforum.zeiss.com/topic/9186-calypso-planner-72-without-virtual-machine/ Share on other sites More sharing options...
[Da...] Posted November 11, 2022 Share Posted November 11, 2022 You must set the correct machine AND size under Extras => Settings => CMM... => Machine and also the correct Probe head / carrier in the "Probe" tab there. Not all CMM are supported, you can check this folder so see what machines and size are implemented: C:\Program Files (x86)\Zeiss\CALYPSO 7.2\cad-components\Machines\ If you are using RDS, you need set some Xs/Ys/Zs values under "Stylus system" tab also and you need bulid all your probes with RDS adapter / XXT sensor too in Stylus System Creator (not only plate + styli). Link to comment https://qualityforum.zeiss.com/topic/9186-calypso-planner-72-without-virtual-machine/#findComment-42180 Share on other sites More sharing options...
[Mi...] Posted November 11, 2022 Author Share Posted November 11, 2022 Yes, the stylus I have already created and they are correct, I think the machine with the dimensions of our Contura G2 does not have it. There is one more issue going on with extracting angles to the Stylus through CAD. I don't understand, because when I select a plane with an inclination of 2.5 degrees, to rotate the head it doesn't rotate, it keeps 0 x 0. Link to comment https://qualityforum.zeiss.com/topic/9186-calypso-planner-72-without-virtual-machine/#findComment-42182 Share on other sites More sharing options...
[Wo...] Posted November 11, 2022 Share Posted November 11, 2022 Aren't Calypso Planner and Simulation two separate options and you have to buy both? Do you have both of them? That's what I remember. Link to comment https://qualityforum.zeiss.com/topic/9186-calypso-planner-72-without-virtual-machine/#findComment-42184 Share on other sites More sharing options...
[To...] Posted November 11, 2022 Share Posted November 11, 2022 It seems that some versions of Planner/Simulation had issues showing some models. Link to comment https://qualityforum.zeiss.com/topic/9186-calypso-planner-72-without-virtual-machine/#findComment-42186 Share on other sites More sharing options...
[Ke...] Posted November 11, 2022 Share Posted November 11, 2022 A list of CMMs and sizes with CAD representation can be found in the attached release notes on pages 133-135, in case this is helpfulZEISS CALYPSO 2021 release notes (7.2.16) EN.pdf Link to comment https://qualityforum.zeiss.com/topic/9186-calypso-planner-72-without-virtual-machine/#findComment-42188 Share on other sites More sharing options...
[Mi...] Posted November 15, 2022 Author Share Posted November 15, 2022 Thank you Link to comment https://qualityforum.zeiss.com/topic/9186-calypso-planner-72-without-virtual-machine/#findComment-42190 Share on other sites More sharing options...
[Ri...] Posted November 15, 2022 Share Posted November 15, 2022 Please sign in to view this quote. Those instructions did not resolve anything. Where the Z mast is, is where it thinks the part is.Capture.JPG Link to comment https://qualityforum.zeiss.com/topic/9186-calypso-planner-72-without-virtual-machine/#findComment-42192 Share on other sites More sharing options...
