[Ra...] Posted November 14, 2022 Share Posted November 14, 2022 I have an program that was written by someone else. There is a " Alignment for several curves " alignment in the program. Every time i go into it , it outputs a error saying " please select feature first". Could any provide any information to why it may be doing this ?132.jpg Link to comment https://qualityforum.zeiss.com/topic/9192-alignment-for-several-curves-question/ Share on other sites More sharing options...
[Ma...] Posted November 14, 2022 Share Posted November 14, 2022 Does this curve recall measured points? Otherwise i have no clue. Link to comment https://qualityforum.zeiss.com/topic/9192-alignment-for-several-curves-question/#findComment-42210 Share on other sites More sharing options...
[Th...] Posted November 14, 2022 Share Posted November 14, 2022 You need more than one curve to use that alignment type, and there's only one in it. Link to comment https://qualityforum.zeiss.com/topic/9192-alignment-for-several-curves-question/#findComment-42212 Share on other sites More sharing options...
[Ma...] Posted November 14, 2022 Share Posted November 14, 2022 Please sign in to view this quote. Are there any changes from 2018 to 2020? I can use this even with one curve - I just need to select appropriate translation/rotation. Link to comment https://qualityforum.zeiss.com/topic/9192-alignment-for-several-curves-question/#findComment-42214 Share on other sites More sharing options...
[Th...] Posted November 14, 2022 Share Posted November 14, 2022 Could be, but I removed my last 2018 install last year. I know the intended path for fitting a single curve is to set the fit parameters in the curve's evaluation settings and using the Alignment button in the same window to create an alignment off that fit if needed. Link to comment https://qualityforum.zeiss.com/topic/9192-alignment-for-several-curves-question/#findComment-42216 Share on other sites More sharing options...
