EXCEL protocol in GEAR
Hi there!
I'm fairly new to GEAR PRO and I'm just getting used to manipulate it...
I like to work with EXCEL for all R&R and analysis purposes, and i found in the "Setup" window the field "EXCEL"...
Sadly i didn't found no advice or instruction how to use that, i suppose I'll have to put some kind of "macros"-File in the selected folder (as in CALYPSO).... but which and where can i find it?
Or am I completely wrong?
Please help, it would make my daily live on work much easier! 🙂
Greetings from Switzerland
Thanks for your reply Roberto!
In CALYPSO i use the EXCEL creator literally every day even without PCM.
With GEAR on the other hand it's a bit tricky... but i think ill gonna find a way
So long!
  • 3 years later...
We managed to work it out via some MACROS on EXCEL, converting the .txt- files spit out by GEAR to a treatable EXCEL-file.
I'll be on vacation the next 12 days, but if you're interestet, i'll gonna send the to you afterwards.
Cheers!
  • 5 months later...
In my active time in GEAR PRO i asked the devellopers what the Excel in GEAR is.
The answer was: it is an alternative editor to change nominal flankform data .
I never had a customer who asked for this alternative edit possibility.
