Question regarding "Define Report" Excel Report.
Is there a way to setup one single excel file where after each run , the data would be inserted into that one file for multiple parts?
Right now Im having to copy and paste alot of data into one single file for compilation.
I do not believe there are any options from within Calypso to do what you are asking but there are many scripts that can accomplish what you need outside of Calypso. I am more familiar with Microsoft PowerShell scripts than any other types, but I would assume you can do it with the language of your choice. If you have PCM, you would use the systemCall() parameter I believe to execute the script of your choice at the end of each run to append an Excel file with the data.
  • 4 weeks later...
