Position E-E
3 radial holes constrain all 6 degrees of freedom. The secondary and tertiary do nothing unless they are releasing DOF somewhere else in the drawing or standard. My best guess is that they want you to create a plane out of the 3 center points and use that as your spatial alignment. Does B-C create a center for the part? Maybe E-E spatial, B-C center, and D clocking?
