Geometry Not Measured Warning
Using Calypso 2022
When I define a point on the surface of a model, I am getting a Geometry Not Measured warning. See screenshots (1-3) below.
If I extract it as a plane and try to add points, I get the same message.
If I add a polyline and then add the points, same thing.
If I add a polyline and have it calculate a path, no problem.
Mystery solved. Restarted Calypso. Must have picked up a hiccup along the way.
Sorry I wasted everyone's time.
Geometry Not Measured 1.jpgGeometry Not Measured 2.jpgGeometry Not Measured 3.jpgGeometry Not Measured 4.jpg
