[Mi...] Posted July 28, 2021 Share Posted July 28, 2021 Does anyone know if PiWeb has the AIAG template like the VDA template for reports? We want to use the AIAG one and its not listed. Maybe on future releases. Does anyone have a workaround? Guess I could make one.... Link to comment https://qualityforum.zeiss.com/topic/9266-templates/ Share on other sites More sharing options...
[1b...] Posted July 29, 2021 Share Posted July 29, 2021 Do you mean this one? Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42602 Share on other sites More sharing options...
[Mi...] Posted July 29, 2021 Author Share Posted July 29, 2021 Yupp Laura that be the one!!!!!!! Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42604 Share on other sites More sharing options...
[1b...] Posted July 29, 2021 Share Posted July 29, 2021 I have this report for PiWeb 7.4. Will that work for you? Anything earlier than 7.4 won't be able to open it, unfortunately. Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42606 Share on other sites More sharing options...
[Mi...] Posted July 29, 2021 Author Share Posted July 29, 2021 Im on 7.8xx Should work Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42608 Share on other sites More sharing options...
[Ya...] Posted August 24, 2021 Share Posted August 24, 2021 Hello, im very interested in such a template. My co workers have still trouble with reading my standart protocols... 🙁 Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42610 Share on other sites More sharing options...
[Gu...] Posted September 2, 2021 Share Posted September 2, 2021 Is this AIAG template used often? If so, where and for which application? Is there a standard description / norm for this? If required, we can deliver such templates with CALYPSO reporting. By the way: We have webinars for tips and functions for the CALYPSO reports. As well as webinars on CALYPSO 2021 innovations and CALYPSO dynamic planning. Webinar overview https://www.zeiss.de/messtechnik/verans ... rdays.html CALYPSO 2021 https://www.zeiss.de/messtechnik/verans ... ights.html CALYPSO 2021 dynamic planning https://www.zeiss.de/messtechnik/verans ... nning.html CALYPSO 2021 reporting https://www.zeiss.de/messtechnik/verans ... ports.html Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42612 Share on other sites More sharing options...
[Mi...] Posted September 9, 2021 Author Share Posted September 9, 2021 Yes Guenter Haas, I use the AIAG form a lot, and if it could be added to the templates for Zeiss that would be great. We in the states use the AIAG for the big 3 automotive. Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42614 Share on other sites More sharing options...
[Jo...] Posted October 19, 2022 Share Posted October 19, 2022 Please sign in to view this quote. Laura, can you share a copy of this? Does Zeiss have a template? Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42616 Share on other sites More sharing options...
[1b...] Posted October 19, 2022 Share Posted October 19, 2022 I don't take ownership of this template. It's been floating around and I modified it a bit to be generic. You'll need to create your own userfields and connect them in the report. Make sure that you create them properly under Resources --> Design custom report --> Editor for user defined report header variables... Create the variables, be sure to map them in the Mapping tab by clicking and dragging them into the K fields. For any fields that you would like to sort, group, or filter by in the future these are important to map. The report defaults to the last 6 pieces. Naturally if the last 6 pieces are not the ones you want to display in the report, use date ranges, measurement attribute searching, or direct selection to find the right records.Big Three Dimensional Template Rev.zip Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42618 Share on other sites More sharing options...
[Jo...] Posted October 20, 2022 Share Posted October 20, 2022 Please sign in to view this quote. Fantastic, Thanks ! Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42620 Share on other sites More sharing options...
[Ja...] Posted October 20, 2022 Share Posted October 20, 2022 Laura, is there a good way to transfer that result info to excel? Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42622 Share on other sites More sharing options...
[1b...] Posted October 20, 2022 Share Posted October 20, 2022 Create a button with the action "Export table data to Excel" and set it to Characteristic table --> View only. This will export the table data in the cells in the same way you see in the report. Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42624 Share on other sites More sharing options...
[Kl...] Posted November 3, 2022 Share Posted November 3, 2022 Hi, template CALYPSO 7.00 A4, english/german Link to comment https://qualityforum.zeiss.com/topic/9266-templates/#findComment-42626 Share on other sites More sharing options...
