[Jo...] Posted October 7, 2022 Share Posted October 7, 2022 I have a PiWeb template I downloaded from somewhere. It is really close to what I need, but I can't get the characteristics to stay in order. Where do I change that ? Link to comment Share on other sites More sharing options...
[Ri...] Posted October 13, 2022 Share Posted October 13, 2022 Please sign in to view this quote. Link to comment Share on other sites More sharing options...
[Ia...] Posted October 13, 2022 Share Posted October 13, 2022 Would anyone mind uploading said AS9102 piweb template? Link to comment Share on other sites More sharing options...
[Jo...] Posted October 13, 2022 Author Share Posted October 13, 2022 I have two copies, both have been modified. One copy works and the other doesn't. I followed Richards instruction. I believe this comes with the latest PiWeb but I couldn't find it on the portal. I'd like to see an original copy as well. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 13, 2022 Share Posted October 13, 2022 Please sign in to view this quote. Here you go. Link to comment Share on other sites More sharing options...
[Jo...] Posted October 17, 2022 Author Share Posted October 17, 2022 Thanks Richard, My last hurdle is getting Characteristic attribute to show up in report. The option to map it is greyed out. Any ideas ? GREY.JPGFetching info... Link to comment Share on other sites More sharing options...
[Je...] Posted October 17, 2022 Share Posted October 17, 2022 You are not in the correct editor. You need to be in the UserFields editor to map variables. Link to comment Share on other sites More sharing options...
[Jo...] Posted October 17, 2022 Author Share Posted October 17, 2022 Please sign in to view this quote. I am trying to assign the characteristic attributes. They are not in the report header menu you show. I can right click the characteristic, and assign the attribute, but cannot find the variable in PiWeb editor to add it to my report. Link to comment Share on other sites More sharing options...
[Kl...] Posted October 21, 2022 Share Posted October 21, 2022 Hello John, I'm also looking for a way to assign K2005 in CALYPSO. Response from Software Support and Product Management, "This feature is only available in SBS and Enterprise" 😮 . The only possibility in PiWeb Reporting Plus: Open DataBase => Show Characteristis => assign K2005, but the next run overwrites the input 🙁 🙁 🙁 ! Link to comment Share on other sites More sharing options...
[Jo...] Posted October 21, 2022 Author Share Posted October 21, 2022 Please sign in to view this quote. I eventually came to that conclusion, that custom variables are not supported with PiWeb Plus. Here is a work around. Use an existing variable that is assigned. Sheet 1 C3 was populated from Characteristic attribute pair.JPGFetching info... locate.JPGFetching info... k2005.JPGFetching info... Link to comment Share on other sites More sharing options...
[Ri...] Posted October 21, 2022 Share Posted October 21, 2022 Please sign in to view this quote. It is a little bit of a pain, but possible. These steps are also how you get around the 10 custom limit setting. Link to comment Share on other sites More sharing options...
[Ri...] Posted October 21, 2022 Share Posted October 21, 2022 Please sign in to view this quote. They are supported, but they just limit you to the mapping portion of it. The main thing to remember is to not use spaces in the internal name portion, you can use underscores though. Link to comment Share on other sites More sharing options...
[Kl...] Posted October 21, 2022 Share Posted October 21, 2022 Hello For me it's very important to assign K2005 directly by CALYPSO like "sample size, sample kind, distribution, ..." to get the full functionality (filter) inside PiWeb Reporting Plus. So output of the value-name pair inside the report isn't the question. It's also confusing the operator to have nearly same labled properties with different behaviour. Question Is there a workaround to assign the bloody name-value pair to the K2005? For all answers, Many thanks. Link to comment Share on other sites More sharing options...
