[Gr...] Posted October 20, 2022 Share Posted October 20, 2022 I have this cone that I need to evaluate. I assume it has been crushed in some way and it wont fit properly the way it did before. How do I tell where this cone has been distorted. Do I do form plot? How exactly do I do that? Link to comment Share on other sites More sharing options...
[To...] Posted October 20, 2022 Share Posted October 20, 2022 Apply some high spot impression blue on the taper. Put it up in the spindle. Then, pull it out and observe where the blue has rubbed off. https://www.google.com/search?q=high+sp ... wQQK0Iz1lM Link to comment Share on other sites More sharing options...
[Ja...] Posted October 20, 2022 Share Posted October 20, 2022 I would scan as much of it as I can and use CAD evaluation. Link to comment Share on other sites More sharing options...
[Ma...] Posted October 20, 2022 Share Posted October 20, 2022 This usually don't bend or deform - didn't they place it into machine 180° rotated? It's stuck 2-3mm out. Don't know size of it, but HSK 63 A have 1:9,98 cone ( aprox. 2,87° ). All i can find is diameter at specified height, but not angle. Link to comment Share on other sites More sharing options...
[Jo...] Posted October 21, 2022 Share Posted October 21, 2022 Please sign in to view this quote. If you know the nominal taper, build the geometry and use best fit profile, CAD deviation to simulate this.. Link to comment Share on other sites More sharing options...
